L-py, an open l-systems frame- FIGURE 13 ? Autre exemple de modélisation de pieds de vigne à partir d'une image. A gauche, l'image originale. A droite, l'image resynthétisée après reconstruction 3D des plantes puis reprojection. work in python, 6th International Workshop on Functional-Structural Plant Models, pp.116-119, 2010. ,
Survey on computer representations of trees for realistic and efficient rendering, pp.2006-2009, 2006. ,
Digital Design of Nature : Computer Generated Plants and Organics Multiple view reconstruction of a quadric of revolution from its occluding contours, ACCV, pp.1-12, 2005. ,
De la reconstruction de quadriques de révolution à partir d'images à la complémentation d'objets naturels, AFIG, 2009. ,
Functionalstructural plant modelling Geometric and algebraic constraints of projected concentric circles and their applications to camera calibration, New Phytologist PAMI, pp.705-708, 2005. ,
Multiple view geometry in computer vision Discriminative learned dictionaries for local image analysis, CVPR, pp.1-8, 2000. ,
Approximate image-based tree-modeling using particle flows, Proc. of SIGGRAPH, 2007. ,
Analysis-by-synthesis by learning to invert generative black boxes, ICANN, pp.971-981, 2008. ,
Self-organizing tree models for image synthesis The algorithmic beauty of plants Image-based plant modeling, The NURBS book, pp.1-10, 1990. ,
Imagebased modeling by joint segmentation, IJCV, pp.135-150, 2007. ,
Volumetric reconstruction and interactive rendering of trees from photographs ,
Vision as bayesian inference : Analysis by synthesis ? Trends in Cognitive Sciences, Probabilistic models of cognition, 2006. ,
3d tree models reconstruction from a single image, ISDA, pp.445-450, 2006. ,
