Generalizing the Hough transform to detect arbitrary shapes, Pattern Recognition, vol.13, issue.2, pp.111-122, 1981. ,
DOI : 10.1016/0031-3203(81)90009-1
Extracting straight lines, IEEE Transactions on Pattern Analysis and Machine Intelligence, issue.4, pp.8425-455, 1986. ,
Image segmentation by a contrario simulation, Pattern Recognition, vol.42, issue.7, pp.1520-1532, 2009. ,
DOI : 10.1016/j.patcog.2009.01.003
URL : https://hal.archives-ouvertes.fr/hal-00847910
Least Squares Fitting of Circles, Journal of Mathematical Imaging and Vision, vol.15, issue.3, pp.239-252, 2005. ,
DOI : 10.1007/s10851-005-0482-8
From Gestalt Theory to Image Analysis, 2008. ,
DOI : 10.1007/978-0-387-74378-3
URL : https://hal.archives-ouvertes.fr/hal-00259077
Robust segmentation of edge data, International Conference on Image Processing and its Applications, pp.311-314, 1992. ,
A fast operator for detection and precise location of distinct points, corners and centres of circular features, Proceedings of Intercommission Conference on Fast Processing of Photogrammetric Data, pp.281-305, 1987. ,
Leastsquares fitting of circles and ellipses, BIT, vol.43, pp.558-578, 1994. ,
Lsd : A fast line segment detector with a false detection control. Pattern Analysis and Machine Intelligence, IEEE Transactions on, vol.32, issue.4, pp.722-732, 2010. ,
Image processing on line ,
Multisegment detection, IEEE International Conference on Image Processing, 2007. ,
Algebraic point set surfaces, ACM Trans. Graph, vol.26, 2007. ,
DOI : 10.1145/1275808.1276406
URL : https://hal.archives-ouvertes.fr/inria-00354998
Fast detection of multi-circle with randomized Hough transform, Optoelectronics Letters, vol.83, issue.5, pp.397-400, 2009. ,
DOI : 10.1007/s11801-009-9071-1
Progressive Probabilistic Hough Transform, Procedings of the British Machine Vision Conference 1998, pp.1-10, 1998. ,
DOI : 10.5244/C.12.26
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.34.9440
Robust Detection of Lines Using the Progressive Probabilistic Hough Transform, Computer Vision and Image Understanding, vol.78, issue.1, pp.119-137, 2000. ,
DOI : 10.1006/cviu.1999.0831
A Probabilistic Criterion to Detect Rigid Point Matches Between Two Images and Estimate the Fundamental Matrix, International Journal of Computer Vision, vol.57, issue.3, pp.201-218, 2004. ,
DOI : 10.1023/B:VISI.0000013094.38752.54
URL : https://hal.archives-ouvertes.fr/hal-00171323
Precise ellipse estimation without contour point extraction. Machine Vision and Applications, 2008. ,
DOI : 10.1007/s00138-008-0141-3
Direct least-squares fitting of algebraic surfaces, ACM SIGGRAPH Computer Graphics, vol.21, issue.4, pp.145-152, 1987. ,
DOI : 10.1145/37402.37420
Code à bulles ,
Estimation of planar curves, surfaces, and nonplanar space curves defined by implicit equations with applications to edge and range image segmentation, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.13, issue.11, pp.1115-1138, 1991. ,
DOI : 10.1109/34.103273
An Improved Method for Circle Detection, Proceedings of the First International Conference on Intelligent Robotics and Applications : Part I, ICIRA '08, pp.463-468, 2008. ,
DOI : 10.1007/978-3-540-88513-9_50
