New interface
Conference papers
An event-based reasoning approach to Web services monitoring
Ehtesham Zahoor 1 Olivier Perrin 1 Claude Godart 1
1 SCORE - Services and Cooperation
Inria Nancy - Grand Est, LORIA - NSS - Department of Networks, Systems and Services
Abstract : In this paper, we propose an event-based framework that allows to specify and reason about the monitoring properties during composition process execution. The proposed approach is highly expressive and allows to specify monitoring properties that can be based on either functional or non-functional requirements, allows multi-level detection of any violation, allows to calculate effects of any such violation on the overall process execution and to recover from it using a set of recovery actions. The choice of a reasoning based approach allows to foresee the effects of violations and respects any functional and non-functional constraints associated with the process, when performing recovery. In addition, as the approach builds upon an event-based declarative framework called DISC, it results in an integrated approach as both composition design and monitoring framework are event-based.
Document type :
Conference papers
Complete list of metadata
Cited literature [19 references]  Display  Hide  Download
https://hal.inria.fr/inria-00596461
Contributor : Ehtesham Zahoor Connect in order to contact the contributor
Submitted on : Friday, May 27, 2011 - 2:51:42 PM
Last modification on : Thursday, April 7, 2022 - 3:08:58 AM
Long-term archiving on: : Friday, November 9, 2012 - 1:50:46 PM
File
DISCMonitoring_ICWS2011.pdf
Identifiers
  • HAL Id : inria-00596461, version 1
Collections
Citation
Ehtesham Zahoor, Olivier Perrin, Claude Godart. An event-based reasoning approach to Web services monitoring. The 9th IEEE International Conference on Web Services (ICWS 2011), Jul 2011, Washington DC, United States. ⟨inria-00596461⟩
Share
Metrics
Record views
205
Files downloads
188
