On the complexity of Gröbner basis computation of semi-regular overdetermined algebraic equations, Proceedings of the International Conference on Polynomial System Solving, pp.71-74, 2004. ,
Asymptotic behaviour of the degree of regularity of semi-regular polynomial systems, Proceedings of Effective Methods in Algebraic Geometry (MEGA), 2005. ,
Combinatorics of maximal minors, Journal of Algebraic Combinatorics, vol.2, issue.2, pp.111-121, 1993. ,
DOI : 10.1023/A:1022492222930
Gröbner bases and determinantal ideals Commutative algebra, singularities and computer algebra, pp.9-66, 2003. ,
An algorithm for finding the basis elements of the residue class ring of a zero dimensional polynomial ideal, Journal of Symbolic Computation, vol.41, pp.3-4, 2006. ,
A Case Study in Bigraded Commutative Algebra, Syzygies and Hilbert functions. Lecture Notes in Pure and Applied Mathematics, 2007. ,
DOI : 10.1201/9781420050912.ch3
Multihomogeneous resultant formulae by means of complexes, Journal of Symbolic Computation, vol.36, issue.3-4, pp.317-342, 2003. ,
DOI : 10.1016/S0747-7171(03)00086-5
Commutative algebra with a view toward algebraic geometry, of Graduate Texts in Mathematics, 1995. ,
Multihomogeneous resultant formulae for systems with scaled support, Proceedings of the 2009 International Symposium on Symbolic and Algebraic Computation, pp.143-150, 2009. ,
Résolution des systemes d'´ equations algébriques, 1994. ,
A new efficient algorithm for computing Gr??bner bases (F4), Journal of Pure and Applied Algebra, vol.139, issue.1-3, pp.61-88, 1999. ,
DOI : 10.1016/S0022-4049(99)00005-5
A new efficient algorithm for computing Gröbner bases without reduction to zero (F5), Proceedings of the 2002 International Symposium on Symbolic and Algebraic Computation (ISSAC), pp.75-83, 2002. ,
Cryptanalysis of MinRank, Proceedings of the 28th Annual conference on Cryptology: Advances in Cryptology, pp.280-296, 2008. ,
DOI : 10.1007/978-3-540-85174-5_16
Solving systems of polynomial equations with symmetries using SAGBI-Gröbner bases, Proceedings of the 2009 International Symposium on Symbolic and Algebraic Computation, pp.151-158, 2009. ,
Computing loci of rank defects of linear matrices using Gröbner bases and applications to cryptology, Proceedings of the 2010 International Symposium on Symbolic and Algebraic Computation, pp.257-264, 2010. ,
An introduction to Gröbner bases, 1997. ,
Theory of codes with maximum rank distance, Problemy Peredachi Informatsii, vol.21, issue.1, pp.3-16, 1985. ,
Algebraic geometry, 1977. ,
DOI : 10.1007/978-1-4757-3849-0
Computing multihomogeneous resultants using straight-line programs, Journal of Symbolic Computation, vol.42, issue.1-2, pp.218-235, 2007. ,
DOI : 10.1016/j.jsc.2006.03.006
Basic Tools for Computing in Multigraded Rings, Commutative Algebra, Singularities and Computer Algebra, pp.197-216, 2003. ,
DOI : 10.1007/978-94-007-1092-4_12
Basic Tools for Computing in Multigraded Rings, Commutative Algebra, Singularities and Computer Algebra, Proc. Conf. Sinaia, pp.197-216, 2002. ,
Gröbner bases, gaussian elimination and resolution of systems of algebraic equations, pp.146-156, 1983. ,
Heuristic methods for computing the minimal multi-homogeneous B??zout number, Applied Mathematics and Computation, vol.146, issue.1, pp.237-256, 2003. ,
DOI : 10.1016/S0096-3003(02)00540-4
Commutative ring theory, 1989. ,
DOI : 10.1017/CBO9781139171762
The complexity of the word problems for commutative semigroups and polynomial ideals, Advances in Mathematics, vol.46, issue.3, pp.305-329, 1982. ,
DOI : 10.1016/0001-8708(82)90048-2
On the resultant of a system of forms homogeneous in each of several sets of variables. Transactions of the, pp.215-233, 1933. ,
A homotopy for solving general polynomial systems that respects m-homogeneous structures, Applied Mathematics and Computation, vol.24, issue.2, pp.101-113, 1987. ,
DOI : 10.1016/0096-3003(87)90063-4
New technique for decoding codes in the rank metric and its cryptography applications, Problems of Information Transmission, vol.38, issue.3, pp.237-246, 2002. ,
DOI : 10.1023/A:1020369320078
Elimination multihomogène. Introduction to Algebraic Independence Theory, Lect. Notes Math, vol.1752, pp.53-81, 2001. ,
Géométrie diophantienne multiprojective, chapitre 7 de Introduction to algebraic independence theory, Lecture Notes in Math, pp.95-131, 2001. ,
Polar varieties and computation of one point in each connected component of a smooth real algebraic set, Proceedings of the 2003 international symposium on Symbolic and algebraic computation , ISSAC '03, pp.224-231, 2003. ,
DOI : 10.1145/860854.860901
URL : https://hal.archives-ouvertes.fr/inria-00099649
Strong bi-homogeneous Bézout theorem and its use in effective real algebraic geometry. Arxiv preprint cs, 2006. ,
Basic Algebraic Geometry 1, 1977. ,
DOI : 10.1007/978-3-642-57908-0
Maximal Minors and Their Leading Terms, Advances in Mathematics, vol.98, issue.1, pp.65-112, 1993. ,
DOI : 10.1006/aima.1993.1013
Hilbert Functions and the Buchberger Algorithm, Journal of Symbolic Computation, vol.22, issue.4, pp.355-376, 1996. ,
DOI : 10.1006/jsco.1996.0056
On Hilbert's Function, Series of Composition of Ideals and a generalization of the Theorem of Bezout, In: Proceedings Roy. Acad. Amsterdam, vol.31, pp.749-770, 1929. ,
Bihomogeneous ideals In this part, we use notations similar to those used in Section ,
the k-vector space of bilinear polynomials in k ,
We say that a property P is generic if it is satisfied on a nonempty open subset of E (for the Zariski topology), i.e. ?h ? k[a 1, such that P does not hold on (a 1 , . . . , a dim(E) ) ? h(a 1 , . . . , a dim(E) ) = 0 ,
