New interface
Conference papers
Algebraic Cryptanalysis of McEliece Variants with Compact Keys
Jean-Charles Faugère 1 Ayoub Otmani 2, 3 Ludovic Perret 1 Jean-Pierre Tillich 2
1 SALSA - Solvers for Algebraic Systems and Applications
LIP6 - Laboratoire d'Informatique de Paris 6, Inria Paris-Rocquencourt
3 Equipe AMACC - Laboratoire GREYC - UMR6072
GREYC - Groupe de Recherche en Informatique, Image et Instrumentation de Caen
Abstract : In this paper we propose a new approach to investigate the security of the McEliece cryptosystem. We recall that this cryptosystem relies on the use of error-correcting codes. Since its invention thirty years ago, no efficient attack had been devised that managed to recover the private key. We prove that the private key of the cryptosystem satisfies a system of bi-homogeneous polynomial equations. This property is due to the particular class of codes considered which are alternant codes. We have used these highly structured algebraic equations to mount an efficient key-recovery attack against two recent variants of the McEliece cryptosystems that aim at reducing public key sizes. These two compact variants of McEliece managed to propose keys with less than 20,000 bits. To do so, they proposed to use quasi-cyclic or dyadic structures. An implementation of our algebraic attack in the computer algebra system MAGMA allows to find the secret-key in a negligible time (less than one second) for almost all the proposed challenges. For instance, a private key designed for a 256-bit security has been found in 0.06 seconds with about 2^17.8 operations.
Document type :
Conference papers
Complete list of metadata
Cited literature [34 references]  Display  Hide  Download
https://hal.inria.fr/inria-00596632
Contributor : Jean-Charles Faugère Connect in order to contact the contributor
Submitted on : Monday, May 30, 2011 - 1:29:39 PM
Last modification on : Thursday, September 15, 2022 - 4:51:08 PM
Long-term archiving on: : Friday, November 9, 2012 - 1:55:32 PM
File
Eurocrypt2010.pdf
Identifiers
Citation
Jean-Charles Faugère, Ayoub Otmani, Ludovic Perret, Jean-Pierre Tillich. Algebraic Cryptanalysis of McEliece Variants with Compact Keys. Eurocrypt 2010 - 29th International Conference on Cryptology, May 2010, Monaco, Monaco. pp.279-298, ⟨10.1007/978-3-642-13190-5_14⟩. ⟨inria-00596632⟩
Share
Metrics
Record views
596
Files downloads
228
