A Comparative Performance Study of the Routing Protocols LOAD and RPL with Bi-Directional Traffic in Low-power and Lossy Networks (LLN)
Routing protocols for sensor networks are often designed with explicit assumptions, serving to simplify design and reduce the necessary energy, processing and communications requirements. Different protocols make different assumptions -- and this memorandum carefully considers those made by the designers of RPL -- an IPv6 routing protocol for such networks, developed within the IETF. Specific attention is given to the predominance of bi-directional traffic flows in a large class of sensor networks, and this memorandum therefore studies the performance of RPL for such flows. As a point of comparison, a different protocol, called LOAD, is also studied. LOAD is derived from AODV and supports more general kinds of traffic flows. The results of this investigation reveal that for scenarios where bi-directional traffic flows are predominant, LOAD provides similar data delivery ratios as RPL, while incurring less overhead and being simultaneously less constrained in the types of topologies supported.
