Retrieval evaluation and distance learning from perceived similarity between endomicroscopy videos - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Evaluating content-based retrieval (CBR) is challenging because it requires an adequate ground-truth. When the available ground-truth is limited to textual metadata such as pathological classes, retrieval results can only be evaluated indirectly, for example in terms of classification performance. In this study we first present a tool to generate perceived similarity ground-truth that enables direct evaluation of endomicroscopic video retrieval. This tool uses a four-points Likert scale and collects subjective pairwise similarities perceived by multiple expert observers. We then evaluate against the generated ground-truth a previously developed dense bag-of-visual-words method for endomicroscopic video retrieval. Confirming the results of previous indirect evaluation based on classification, our direct evaluation shows that this method significantly outperforms several other state-of-the-art CBR methods. In a second step, we propose to improve the CBR method by learning an adjusted similarity metric from the perceived similarity ground-truth. By minimizing a margin-based cost function that differentiates similar and dissimilar video pairs, we learn a weight vector applied to the visual word signatures of videos. Using cross-validation, we demonstrate that the learned similarity distance is significantly better correlated with the perceived similarity than the original visual-word-based distance.
Barbara_ANDRE_MICCAI11_CameraReadyFinal.pdf (445.59 Ko) Télécharger le fichier
Barbara_ANDRE_MICCAI11_SupplementaryMaterial.pdf (227.71 Ko) Télécharger le fichier
inria-00598301 , version 1 (06-06-2011)
Barbara André, Tom Vercauteren, Anna Buchner, Michael Wallace, Nicholas Ayache. Retrieval evaluation and distance learning from perceived similarity between endomicroscopy videos. Medical Image Computing and Computer-Assisted Intervention - MICCAI 2011, 2011, Toronto, Canada. pp.297-304, ⟨10.1007/978-3-642-23626-6_37⟩. ⟨inria-00598301⟩
187 Consultations
153 Téléchargements
