Signal enhancement based on Hölder regularity analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2002
We present a approach for signal enhancement based on the analysis of the local Hölder regularity. The method does not make explicit assumptions on the type of noise or on the global smoothness of the original data, but rather supposes that signal enhancement is equivalent to increasing the Hölder regularity each point. Such a scheme is well adapted to the case where the signal to be recovered is itself very irregular, e.g. nowhere differentiable with rapidly varying local regularity. In particular, we show an application to SAR image denoting where this technique yields good results compared to other algorithms.
Signal-enhancement-based-on-holder-regularity-analysis.pdf (457 Ko) Télécharger le fichier
inria-00598355 , version 1 (06-06-2011)
  • HAL Id : inria-00598355 , version 1
Jacques Lévy Véhel. Signal enhancement based on Hölder regularity analysis. Michael F. Barnsley, Dietmar Saupe, and Edward Vrscay. Fractals in Multimedia, 132, Springer Science and Business Media, pp.197-209, 2002, The IMA Volumes in Mathematics and its Applications. ⟨inria-00598355⟩
Collections
INRIA INRIA2
106 Consultations
238 Téléchargements
