Journal articles
Analysis of joint maintenance and production policies under a subcontracting constraint
Abstract : In this paper, we deal with the problem of joint maintenance and production management under a subcontracting constraint. We will study a system with a machine M which undergoes corrective maintenance actions together with preventive maintenance actions, both of which have random durations. A stock S with a capacity h is developed at a rate agr = Umax - d, where Umax = production rate, d = constant demand, and Umax > d. In addition, machine M is allocated to carry out subcontracting tasks (ST) at a frequency A1, for an effective duration A2, during which time it cannot be used to fulfil our system's demand d. We initially study the system analytically when the machine M is forced to carry out a single subcontracting task during each cycle T. We thereafter present a generalization of the subcontracting constraint which entails assigning the machine M to subcontracting several times during each cycle.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/inria-00598598
Contributor : Ist Inria Nancy Grand Est Connect in order to contact the contributor
Submitted on : Tuesday, June 7, 2011 - 9:42:03 AM
Last modification on : Friday, February 4, 2022 - 3:24:49 AM
Identifiers
Collections
Citation
Mohammed Dahane, Christian Clémentz, Nidhal Rezg. Analysis of joint maintenance and production policies under a subcontracting constraint. International Journal of Production Research, Taylor & Francis, 2008, 46 (19), pp.5393 - 5416. ⟨10.1080/00207540802273686⟩. ⟨inria-00598598⟩
Share
Metrics
Record views
42
