Development of joint maintenance and production strategies in a subcontracting environment
Abstract : This article, inspired by an industrial problem, develops efficient maintenance and just-in-time production policies in a subcontracting environment according to two orientations. The first invokes subcontracting with the objective of satisfying a constant customer demand knowing that our production system, composed of a machine M1, cannot satisfy the totality of demand. Subcontracting is represented by a machine M2 which has a constant failure rate, while three maintenance policies for M1 are tested and evaluated. The second orientation takes the perspective of our production system as a supplier which is obliged to allocate part of its production capacity to subcontracting so as to satisfy a constant demand. We consider a production system made up of two machines, both of which produce a single type of product, are subject to breakdowns and can carry out subcontracting tasks. The objective of this part of the article is to prove the efficiency of the so-called integrated maintenance policy, which combines production and maintenance decisions in a subcontracting environment.
Type de document :
Article dans une revue
International Journal of Production Research, Taylor & Francis, 2011, 〈10.1080/00207543.2010.519173〉
Liste complète des métadonnées
https://hal.inria.fr/inria-00598601
Contributeur : Ist Inria Nancy Grand Est <>
Soumis le : mardi 7 juin 2011 - 09:53:47
Dernière modification le : mardi 27 février 2018 - 15:44:03
Collections
Citation
Mohammed Dahane, Sofiene Dellagi, Christian Clémentz, Nidhal Rezg. Development of joint maintenance and production strategies in a subcontracting environment. International Journal of Production Research, Taylor & Francis, 2011, 〈10.1080/00207543.2010.519173〉. 〈inria-00598601〉
Métriques
Consultations de la notice
123
