Speech Signal Modeling Based on Local Regularity Analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1995
In this paper, we propose a new approach for modeling speech signals. The principle of this approach consists in using a generalisation of iterated functions systems theory (IFS) to give a robust functional representation of speech signals, based on the analysis of the local regularities of the waveforms. This approach is motivated by the fact that the local singularities, measured in terms of H�lder exponents [1], contains crucial information on the voice signal. We show that this technique allows to describe some characteristic features of the speaker and to build a parsimonious model of the speech signal, which permits to synthesize it with a good accuracy.
Fichier non déposé
inria-00598729 , version 1 (07-06-2011)
  • HAL Id : inria-00598729 , version 1
Daoudi Khalid, Jacques Lévy Véhel. Speech Signal Modeling Based on Local Regularity Analysis. IASTED/IEEE International Conference on Signal and Image Processing (SIP'95), Nov 1995, Las Vegas, United States. ⟨inria-00598729⟩
Collections
INRIA INRIA2
43 Consultations
0 Téléchargements
