New interface
Reports (Research report)
An RMS for Non-predictably Evolving Applications
Cristian Klein 1 Christian Pérez 1
1 GRAAL - Algorithms and Scheduling for Distributed Heterogeneous Platforms
Inria Grenoble - Rhône-Alpes, LIP - Laboratoire de l'Informatique du Parallélisme
Abstract : Non-predictably evolving applications are applications that change their resource requirements during execution. These applications exist, for example, as a result of using adaptive numeric methods, such as adaptive mesh refinement and adaptive particle methods. Increasing interest is being shown to have such applications acquire resources on the fly. However, current HPC Resource Management Systems (RMSs) only allow a static allocation of resources, which cannot be changed after it started. Therefore, non-predictably evolving applications cannot make efficient use of HPC resources, being forced to make an allocation based on their maximum expected requirements. This paper presents CooRMv2, an RMS which supports efficient scheduling of non-predictably evolving applications. An application can make "pre-allocations" to specify its peak resource usage. The application can then dynamically allocate resources as long as the pre-allocation is not outgrown. Resources which are pre-allocated but not used, can be filled by other applications. Results show that the approach is feasible and leads to a more efficient resource usage.
Document type :
Complete list of metadata
Cited literature [22 references]  Display  Hide  Download
https://hal.inria.fr/inria-00599150
Contributor : Cristian Klein Connect in order to contact the contributor
Submitted on : Thursday, June 9, 2011 - 4:57:40 PM
Last modification on : Wednesday, October 26, 2022 - 8:16:01 AM
Long-term archiving on: : Thursday, March 30, 2017 - 11:39:27 AM
File
main.good.pdf
Identifiers
  • HAL Id : inria-00599150, version 3
Citation
Cristian Klein, Christian Pérez. An RMS for Non-predictably Evolving Applications. [Research Report] RR-7644, INRIA. 2011. ⟨inria-00599150v3⟩
Share
Metrics
Record views
118
Files downloads
353
