Robot development: from components to systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
While the last twenty years have seen the development of numerous robot integration frameworks, the last years have seen some kind of a consolidation. The obvious suspect being ROS [11], with trailing behind Orocos/RTT [13], OpenRobots and OpenRTM-aist; there are also older frameworks like MCA [12], which seem to have stopped their development, but provided basic ideas the aforementioned systems. This is list by no means meant to be exhaustive, it just lists { from the point of view of the authors { what component layers are getting adopted in the community to date.
Joyeux-Rock.PDF (468.14 Ko) Télécharger le fichier
inria-00599679 , version 1 (10-06-2011)
  • HAL Id : inria-00599679 , version 1
Sylvain Joyeux, Jan Albiez. Robot development: from components to systems. 6th National Conference on Control Architectures of Robots, INRIA Grenoble Rhône-Alpes, May 2011, Grenoble, France. 15 p. ⟨inria-00599679⟩
Collections
CAR-2011
589 Consultations
596 Téléchargements
