Conference papers
Initial populations tests for genetic algorithm flowshop scheduling problems solving with a special blocking
Abstract : In this paper, we consider a flowshop scheduling problem with a special blocking RCb (Release when Completing Blocking). This flexible production system is prevalent in some industrial environments. We propose genetic algorithms for solving these flowshop problems and different initial populations are tested to find the best adapted. Then, different parameters sets are tested in order to find the best for further genetic algorithms populations selection. Best parameters set and results are endly discussed.
Complete list of metadata
https://hal.inria.fr/inria-00600379
Contributor : Ist Inria Nancy Grand Est Connect in order to contact the contributor
Submitted on : Tuesday, June 14, 2011 - 4:40:17 PM
Last modification on : Friday, February 4, 2022 - 3:17:43 AM
Identifiers
Collections
Citation
Christophe Sauvey, Nathalie Sauer. Initial populations tests for genetic algorithm flowshop scheduling problems solving with a special blocking. 13th IFAC Symposium on Information Control problems in manufacturing, Jun 2009, Moscou, Russia. pp.1961-1966, ⟨10.3182/20090603-3-RU-2001.00330⟩. ⟨inria-00600379⟩
Share
Metrics
Record views
66
