DCA for Minimizing the Cost and Tardiness of Preventive Maintenance Tasks under Real-Time Allocation Constraint - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2010
In this paper, we introduce a new approach based on DC (Difference of Convex functions) Programming and DCA (DC Algorithm) for minimizing the maintenance cost involving flow-time and tardiness penalties. The main idea is to divide the horizon considered into H intervals and the problem is first formulated as a mixed integer linear problem (MILP). It is afterward reformulated in the form of a DC program by an exact penalty technique. Solution method based on DCA is investigated to solve the resulting problem. The efficiency of DCA is compared with the algorithm based on the new flow-time and tardiness rule (FTR) given in [8]. The computational results on several test problems show that the solutions provided by DCA are better.
inria-00601072 , version 1 (16-06-2011)
Tran Duc Quynh, Le Thi Hoai An, Kondo-Hloindo Adjallah. DCA for Minimizing the Cost and Tardiness of Preventive Maintenance Tasks under Real-Time Allocation Constraint. Ngoc Thanh Nguyen and Manh Thanh Le and Jerzy Swiatek. Intelligent Information and Database Systems Second International Conference, ACIIDS Proceedings part II, 5991, Springer, pp.410-419, 2010, Lecture Notes in Computer Science, 978-3-642-12100-5. ⟨10.1007/978-3-642-12101-2_42⟩. ⟨inria-00601072⟩
106 Consultations
0 Téléchargements
