Virtual Texture Mapping 101 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2010
Modern games and applications use large amounts of texture data; the number and the resolution of textures also continues to grow quickly. However, the amount of available graphics memory is not growing at the same pace and, in addition to textures, GPU memory is also used for complex post-processing effects and lighting calculations. Virtual Texture Mapping (VTM) is a technique to reduce the amount of graphics memory required for textures to a point where it is only dependent on the screen resolution: for a given viewpoint we only keep the visible parts of the textures in graphics memory, at the appropriate MIP map level. In this chapter, we investigate how to implement a fully functional VTM system.
Fichier non déposé
inria-00601729 , version 1 (20-06-2011)
  • HAL Id : inria-00601729 , version 1
Matthäus Chajdas, Christian Eisenacher, Sylvain Lefebvre. Virtual Texture Mapping 101. Wolfgang Engel. GPU Pro, AK Peters, 2010, 978-1-56881-472-8. ⟨inria-00601729⟩
533 Consultations
0 Téléchargements
