On-board Evolutionary Algorithm and Off-line Rule Discovery for Column Formation in Swarm Robotics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper aims at building autonomous controllers for swarm robots, specifically aimed at enforcing a given shape formation, here a column formation. The proposed approach features two main characteristics. Firstly, a state-of-the-art evolutionary setting is used to achieve the on-board optimization of the controller, avoiding any simulator-based approach. Secondly, as the cost of physical experiments might be prohibitively high for plain evolutionary approaches, a data mining approach is achieved on the top of evolution; rule discovery is used to discover the most promising regions in the controller search space. The merits of the approach are experimentally validated using a 5 robot formation, showing that the hybrid evolutionary learning process outperforms evolution alone in terms of swarm speed and shape quality.
2011-IAT-suzuki.pdf (168.68 Ko) Télécharger le fichier
inria-00601785 , version 1 (20-06-2011)
  • HAL Id : inria-00601785 , version 1
Asuki Kuno, Jean-Marc Montanier, Shigeru Takano, Nicolas Bredeche, Marc Schoenauer, et al.. On-board Evolutionary Algorithm and Off-line Rule Discovery for Column Formation in Swarm Robotics. IEEE/ACM/WIC International Conference on Intelligent Agent Technology, Aug 2011, Lyon, France. ⟨inria-00601785⟩
304 Consultations
433 Téléchargements
