Conference papers
SCIPX: a SystemC to IP-XACT extraction tool
Jean-François Le Tallec 1, * Robert de Simone 1
* Corresponding author
1 AOSTE - Models and methods of analysis and optimization for systems with real-time and embedding constraints
CRISAM - Inria Sophia Antipolis - Méditerranée , Inria Paris-Rocquencourt, Laboratoire I3S - COMRED - COMmunications, Réseaux, systèmes Embarqués et Distribués
Abstract : The IP-Xact formalism (IEEE 1685 standard), was introduced to help assemble IP components from distinct sources into an integrated design. Components would be expressed in high-level HDLs such as SystemC, and so should be the full design after composition. Currently, while components exist at SystemC level, they generally do not provide any local IP-Xact structural interface representation. The present contribution studies the difficulties in creating such an IP-Xact interface declaration from SystemC, solves most of them, and provide SystemC modeling guidelines so that a richer set of informations can be recovered and reported into IP-Xact.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/inria-00601843
Contributor : Team Kairos Connect in order to contact the contributor
Submitted on : Monday, June 20, 2011 - 5:33:14 PM
Last modification on : Friday, January 21, 2022 - 3:16:09 AM
Identifiers
  • HAL Id : inria-00601843, version 1
Collections
Citation
Jean-François Le Tallec, Robert de Simone. SCIPX: a SystemC to IP-XACT extraction tool. ESLsyn : Electronic System Level Synthesis Conference, Jun 2011, San Diego, United States. ⟨inria-00601843⟩
Share
Metrics
Les métriques sont temporairement indisponibles
