Signal Recovery by Proximal Forward-Backward Splitting, Multiscale Modeling & Simulation, vol.4, issue.4, pp.1168-1200, 2005. ,
DOI : 10.1137/050626090
URL : https://hal.archives-ouvertes.fr/hal-00017649
Richardson???Lucy algorithm with total variation regularization for 3D confocal microscope deconvolution, Microscopy Research and Technique, vol.59, issue.4, pp.260-266, 2006. ,
DOI : 10.1002/jemt.20294
A Proximal Iteration for Deconvolving Poisson Noisy Images Using Sparse Representations, IEEE Transactions on Image Processing, vol.18, issue.2, pp.310-321, 2009. ,
DOI : 10.1109/TIP.2008.2008223
Restoration of Poissonian Images Using Alternating Direction Optimization, IEEE Transactions on Image Processing, vol.19, issue.12, pp.3133-3145, 2010. ,
DOI : 10.1109/TIP.2010.2053941
An iterative technique for the rectification of observed distributions, The Astronomical Journal, vol.79, issue.6, pp.745-765, 1974. ,
DOI : 10.1086/111605
Image Denoising in Mixed Poisson–Gaussian Noise, IEEE Transactions on Image Processing, vol.20, issue.3, pp.696-708, 2011. ,
DOI : 10.1109/TIP.2010.2073477
Hybrid regularization for data restoration in the presence of Poisson noise, European Signal Processing Conference, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00621941
??ber die Verwendung des Morozovschen Diskrepanz Prinzips bei Tikhonov Regularisierung zur L??sung nichtlinearer inkorrekt gestellter Probleme, Computing, vol.5, issue.1, pp.45-60, 1993. ,
DOI : 10.1007/BF02243828
