Enumerating the edge-colourings and total colourings of a regular graph - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2011
In this paper, we are interested in computing the number of edge colourings and total colourings of a graph. We prove that the maximum number of $k$-edge-colourings of a $k$-regular graph on $n$ vertices is $k\cdot(k-1!)^{n/2}$. Our proof is constructible and leads to a branching algorithm enumerating all the $k$-edge-colourings of a $k$-regular graph using a time $O^*((k-1!)^{n/2})$ and polynomial space. In particular, we obtain a algorithm on time $O^*(2^{n/2})=O^*(1.4143^n)$ and polynomial space to enumerate all the $3$-edge colourings of a cubic graph, improving the running time of $O^*(1.5423^n)$ of the algorithm due to Golovach et al.~\cite{GKC10}. We also show that the number of $4$-total-colourings of a connected cubic graph is at most $3.2^{3n/2}$. Again, our proof yields a branching algorithm to enumerate all the $4$-total-colourings of a connected cubic graph.
RR-7652.pdf (231.41 Ko) Télécharger le fichier
inria-00602188 , version 1 (21-06-2011)
  • HAL Id : inria-00602188 , version 1
Stéphane Bessy, Frédéric Havet. Enumerating the edge-colourings and total colourings of a regular graph. [Research Report] RR-7652, INRIA. 2011. ⟨inria-00602188⟩
214 Consultations
170 Téléchargements
