GPU-Assisted Computation of Centroidal Voronoi Tessellation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Visualization and Computer Graphics Année : 2011
Centroidal Voronoi tessellations (CVT) are widely used in computational science and engineering. The most commonly used method is Lloyd's method, and recently the L-BFGS method is shown to be faster than Lloyd's method for computing the CVT. However, these methods run on the CPU and are still too slow for many practical applications. We present techniques to implement these methods on the GPU for computing the CVT on 2D planes and on surfaces, and demonstrate significant speedup of these GPU-based methods over their CPU counterparts. For CVT computation on a surface, we use a geometry image stored in the GPU to represent the surface for computing the Voronoi diagram on the surface. In our implementation a new technique is proposed for parallel regional reduction on the GPU for evaluating integrals over Voronoi cells.
GPU-CVT.pdf (5.22 Mo) Télécharger le fichier
inria-00602490 , version 1 (22-06-2011)
Guodong Rong, Yang Liu, Wenping Wang, Xaotian Yin, Xianfeng Gu, et al.. GPU-Assisted Computation of Centroidal Voronoi Tessellation. IEEE Transactions on Visualization and Computer Graphics, 2011, 17 (3), pp.345-356. ⟨10.1109/TVCG.2010.53⟩. ⟨inria-00602490⟩
154 Consultations
614 Téléchargements
