New interface
Journal articles
Caviz, An interactive graphical tool for image mining
Khang-Nguyen Pham 1 Annie Morin 2 Patrick Gros 2
2 TEXMEX - Multimedia content-based indexing
IRISA - Institut de Recherche en Informatique et Systèmes Aléatoires, Inria Rennes – Bretagne Atlantique
Abstract : We propose an interactive graphical tool, CAViz, which allows us to display and to extract knowledge from the results of a Correspondence Analysis CA on images. CA is a descriptive technique designed to analyze simple two-way and multi-way tables containing some measure of correspondence between the rows and columns. CA is very often used in Textual Data Analysis (TDA) where the contingency table crosses words and documents. In image mining, the first step is to define ldquovisualrdquo words in images (similar to words in texts). These words are constructed from local descriptors (SIFT, Scale Invariant Feature Transform) in images. Our tool CAViz is interactive, and it helps the user interpretating the results and the graphs of CA. An application to the Caltech4 base (Sivic et al., 2005) illustrates the interest of CAViz in image mining.
Document type :
Journal articles
Complete list of metadata
https://hal.inria.fr/inria-00603333
Contributor : Patrick Gros Connect in order to contact the contributor
Submitted on : Friday, June 24, 2011 - 4:06:38 PM
Last modification on : Wednesday, February 2, 2022 - 3:59:33 PM
Identifiers
  • HAL Id : inria-00603333, version 1
Citation
Khang-Nguyen Pham, Annie Morin, Patrick Gros. Caviz, An interactive graphical tool for image mining. Journal of Computing and Information Technology, 2008, 16 (4), pp.295-302. ⟨inria-00603333⟩
Share
Metrics
Record views
177
