Estimation techniques for distributed parameter systems, volume 1 of Systems & Control: Foundations & Applications, Birkhäuser Boston Inc, 1989. ,
Filtrage optimal des systèmes linéaires. Dunod, 1971. ,
Luenberger-based state estimation in vascular fluid-structure interaction through measurements in the solid, 2011. ,
Filteringbased data assimilation in fluid-structure interaction: towards personalization of vascular models, 1st International Conference on Mathematical and Computational Biomedical Engineering -CMBE, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00793415
Nonlinear least squares for inverse problems. Scientific Computation Theoretical foundations and step-by-step guide for applications, 2009. ,
Applications of variational data assimilation in computational hemodynamics, 2011. ,
Data assimilation: the ensemble Kalman filter, 2009. ,
DOI : 10.1007/978-3-642-03711-5
Coupling schemes for incompressible fluid-structure interaction: implicit, semi-implicit and explicit, SeMA Journal, vol.40, issue.12, 2011. ,
DOI : 10.1007/BF03322593
Fluid structure interaction problems in haemodynamics, chapter 9, Cardiovascular Mathematics . Modeling and simulation of the circulatory system, L. Formaggia, A. Quarteroni, A. Veneziani editors, 2009. ,
A projection algorithm for fluid???structure interaction problems with strong added-mass effect, Comptes Rendus Mathematique, vol.342, issue.4, pp.279-284, 2006. ,
DOI : 10.1016/j.crma.2005.12.017
A projection semi-implicit scheme for the coupling of an elastic structure with an incompressible fluid, International Journal for Numerical Methods in Engineering, vol.9, issue.4, pp.794-821, 2007. ,
DOI : 10.1002/nme.1792
of Modeling, Simulation and Applications, Cardiovascular Mathematics. Modeling and simulation of the circulatory system, 2009. ,
A simplified reduced order Kalman filtering and application to altimetric data assimilation in Tropical Pacific, Journal of Marine Systems, vol.36, issue.1-2, pp.101-127, 2002. ,
DOI : 10.1016/S0924-7963(02)00129-X
The spherical simplex unscented transformation, Proceedings of the 2003 American Control Conference, 2003., pp.2430-4234, 2003. ,
DOI : 10.1109/ACC.2003.1243439
A new approach for filtering nonlinear systems, Proceedings of 1995 American Control Conference, ACC'95, pp.1628-1632, 1995. ,
DOI : 10.1109/ACC.1995.529783
A new method for the nonlinear transformation of means and covariances in filters and estimators. Automatic Control, IEEE Transactions on, vol.45, issue.3, pp.477-482, 2000. ,
Linear estimation, 2000. ,
New Results in Linear Filtering and Prediction Theory, Journal of Basic Engineering, vol.83, issue.1, pp.95-108, 1961. ,
DOI : 10.1115/1.3658902
An inverse technique to deduce the elasticity of a large artery, The European Physical Journal Applied Physics, vol.9, issue.2, pp.153-163, 1999. ,
DOI : 10.1051/epjap:2000213
An introduction to observers, IEEE Transactions on Automatic Control, vol.16, issue.6, pp.596-602, 1971. ,
DOI : 10.1109/TAC.1971.1099826
Parameter identification for a one-dimensional blood flow model, ESAIM-Proceedings, pp.174-200, 2005. ,
DOI : 10.1051/proc:2005014
URL : https://hal.archives-ouvertes.fr/hal-00700366
Erratum of article ???Reduced-order Unscented Kalman Filtering with application to parameter identification in large-dimensional systems???, ESAIM: Control, Optimisation and Calculus of Variations, vol.17, issue.2, pp.406-409, 2011. ,
DOI : 10.1051/cocv/2011001
Reduced-order Unscented Kalman Filtering with application to parameter identification in large-dimensional systems, ESAIM: Control, Optimisation and Calculus of Variations, vol.17, issue.2, pp.380-405, 2011. ,
DOI : 10.1051/cocv/2010006
URL : https://hal.archives-ouvertes.fr/inria-00550104
Joint state and parameter estimation for distributed mechanical systems, Computer Methods in Applied Mechanics and Engineering, vol.197, issue.6-8, pp.659-677, 2008. ,
DOI : 10.1016/j.cma.2007.08.021
URL : https://hal.archives-ouvertes.fr/hal-00175623
Filtering for distributed mechanical systems using position measurements: perspectives in medical imaging, Inverse Problems, vol.25, issue.3, pp.35010-035035, 2009. ,
DOI : 10.1088/0266-5611/25/3/035010
URL : https://hal.archives-ouvertes.fr/hal-00358914
External tissue support and fluid???structure simulation in blood flows, Biomechanics and Modeling in Mechanobiology, vol.31, issue.3, pp.10-1007, 2011. ,
DOI : 10.1007/s10237-011-0289-z
URL : https://hal.archives-ouvertes.fr/hal-00701801
Filtres de Kalman singuliers évolutifs pour l'assimilation de données en océanographie, Comptes Rendus de l'Académie des Sciences -Series IIA, pp.255-260, 1998. ,
DOI : 10.1016/s1251-8050(97)86815-2
Optimal state estimation: Kalman, H infinity, and nonlinear approaches, 2006. ,
DOI : 10.1002/0470045345
Kalman filtering with state constraints: a survey of linear and nonlinear algorithms, IET Control Theory & Applications, vol.4, issue.8, 2009. ,
DOI : 10.1049/iet-cta.2009.0032
A singular evolutive extended kalman filter for data assimilation in oceanography, Journal of Marine systems, vol.16, pp.3-4323, 1998. ,
Myocardial transversely isotropic material parameter estimation from in-silico measurements based on a reduced-order unscented Kalman filter, Journal of the Mechanical Behavior of Biomedical Materials, vol.4, issue.7, 2011. ,
DOI : 10.1016/j.jmbbm.2011.03.018
