Injectivity Radius Estimates and Sphere Theorems, Comparison Geometry. Mathematical Sciences Research Institute (MSRI) Publications, 1997. ,
A Simple Algorithm for Homeomorphic Surface Reconstruction, Internat. Journal of Comput ,
Geometry 2. Universitext, 1990. ,
Isosurface construction in any dimension using convex hulls, IEEE Transactions on Visualization and Computer Graphics, vol.10, issue.2, pp.130-144, 2004. ,
DOI : 10.1109/TVCG.2004.1260765
A coordinate system associated with points scattered on a surface, Computer-Aided Design, vol.36, issue.2, pp.161-174, 2004. ,
DOI : 10.1016/S0010-4485(03)00059-9
Manifold Reconstruction using Tangential Delaunay Complexes, Proc. 26th Annual Symposium on Computational Geometry, 2010. ,
DOI : 10.1145/1810959.1811013
URL : https://hal.archives-ouvertes.fr/inria-00440337
Provably good sampling and meshing of surfaces, Graphical Models, vol.67, issue.5, pp.405-451, 2005. ,
DOI : 10.1016/j.gmod.2005.01.004
URL : https://hal.archives-ouvertes.fr/hal-00488829
Provably good sampling and meshing of Lipschitz surfaces, Proceedings of the twenty-second annual symposium on Computational geometry , SCG '06, pp.337-346, 2006. ,
DOI : 10.1145/1137856.1137906
Locally uniform anisotropic meshing, Proceedings of the twenty-fourth annual symposium on Computational geometry , SCG '08, pp.270-277, 2008. ,
DOI : 10.1145/1377676.1377724
URL : https://hal.archives-ouvertes.fr/inria-00275430
A simple triangulation method for smooth manifolds, Bulletin of the American Mathematical Society, vol.67, issue.4, pp.389-390, 1961. ,
DOI : 10.1090/S0002-9904-1961-10631-9
Delaunay Triangulation Based Surface Reconstruction, Effective Computational Geometry for Curve and Surfaces, 2006. ,
DOI : 10.1007/978-3-540-33259-6_6
URL : https://hal.archives-ouvertes.fr/inria-00070609
Finite propagation speed, kernel estimates for functions of the Laplace operator, and the geometry of complete Riemannian manifolds, Journal of Differential Geometry, vol.17, issue.1, pp.15-53, 1982. ,
DOI : 10.4310/jdg/1214436699
Manifold Reconstruction from Point Samples, Proc. of ACM-SIAM Symp. Discrete Algorithms, pp.1018-1027, 2005. ,
Guaranteed-Quality Delaunay Meshing in 3D, Proc. ACM Symp. on Computational Geometry, pp.391-393, 2006. ,
Building triangulations using ??-nets, Proceedings of the thirty-eighth annual ACM symposium on Theory of computing , STOC '06, pp.326-335, 2006. ,
DOI : 10.1145/1132516.1132564
Topology from Data via Geodesic complexes, 2009. ,
Metric entropy of some classes of sets with differentiable boundaries, Journal of Approximation Theory, vol.10, issue.3, pp.227-236, 1974. ,
DOI : 10.1016/0021-9045(74)90120-8
Geometry and Topology for Mesh Generation, 2001. ,
Curvature Measures. Transactions of the, pp.418-491, 1959. ,
DOI : 10.1090/s0002-9947-1959-0110078-1
Geometric measure theory, 1969. ,
DOI : 10.1007/978-3-642-62010-2
Convergence of curvatures in secant approximations, Journal of Differential Geometry, vol.37, issue.1, pp.177-190, 1993. ,
DOI : 10.4310/jdg/1214453427
Shape Dimension and Intrinsic Metric from Samples of Manifolds, Proc. of ACM Symp. on Computational Geometry, pp.329-337, 2003. ,
DOI : 10.1007/s00454-004-1120-8
Asymptotic estimates for best and stepwise approximation of convex bodies I, Forum Mathematicum, vol.5, issue.5, pp.281-297, 1993. ,
DOI : 10.1515/form.1993.5.281
Optimum quantization and its applications, Advances in Mathematics, vol.186, issue.2, pp.456-497, 2004. ,
DOI : 10.1016/j.aim.2003.07.017
URL : http://doi.org/10.1016/j.aim.2003.07.017
MULTIPLE PARAMETER CONTINUATION: COMPUTING IMPLICITLY DEFINED k-MANIFOLDS, International Journal of Bifurcation and Chaos, vol.12, issue.03, pp.451-476, 2002. ,
DOI : 10.1142/S0218127402004498
The initial convergence rate of adaptive methods for polyhedral approximation of convex bodies, Computational Mathematics and Mathematical Physics, vol.48, issue.5, pp.724-738, 2008. ,
DOI : 10.1134/S0965542508050035
Generating well-shaped d-dimensional Delaunay Meshes, Theoretical Computer Science, vol.296, issue.1, pp.145-165, 2003. ,
DOI : 10.1016/S0304-3975(02)00437-1
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.57.8524
Simplicial isosurfacing in arbitrary dimension and codimension, Journal of Computational Physics, vol.190, issue.1, pp.295-310, 2003. ,
DOI : 10.1016/S0021-9991(03)00275-4
Finding the Homology of Submanifolds with High Confidence from??Random??Samples, Discrete & Computational Geometry, vol.33, issue.11, pp.419-441, 2008. ,
DOI : 10.1007/s00454-008-9053-2
Geodesic Computations for Fast and Accurate Surface Remeshing and Parameterization, Progress in Nonlinear Differential Equations and Their Applications, pp.157-171, 2005. ,
DOI : 10.1007/3-7643-7384-9_18
A Delaunay Refinement Algorithm for Quality 2-Dimensional Mesh Generation, Journal of Algorithms, vol.18, issue.3, pp.548-585, 1995. ,
DOI : 10.1006/jagm.1995.1021
On C 1 -Complexes, The Annals of Mathematics, vol.41, issue.4, pp.809-824, 1940. ,
DOI : 10.2307/1968861
Geometric Integration Theory, route des Lucioles -BP 93 -06902 Sophia, 1957. ,
DOI : 10.1515/9781400877577
