An image-based approach to video copy detection with spatio-temporal post-filtering - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Multimedia Année : 2010
This paper introduces a video copy detection system which efficiently matches individual frames and then verifies their spatio-temporal consistency. The approach for matching frames relies on a recent local feature indexing method, which is at the same time robust to significant video transformations and efficient in terms of memory usage and computation time. We match either keyframes or uniformly sampled frames. To further improve the results, a verification step robustly estimates a spatio-temporal model between the query video and the potentially corresponding video segments. Experimental results evaluate the different parameters of our system and measure the trade-off between accuracy and efficiency. We show that our system obtains excellent results for the TRECVID 2008 copy detection task.
Mots clés
douze_tmm.pdf (723.68 Ko) Télécharger le fichier
Format : Figure, Image
inria-00604034 , version 1 (28-06-2011)
Matthijs Douze, Hervé Jégou, Cordelia Schmid. An image-based approach to video copy detection with spatio-temporal post-filtering. IEEE Transactions on Multimedia, 2010, 12 (4), pp.257-266. ⟨10.1109/TMM.2010.2046265⟩. ⟨inria-00604034⟩
497 Consultations
851 Téléchargements
