Joint source-channel decoding of variable-length encoded sources, 1998 Information Theory Workshop (Cat. No.98EX131), pp.94-95, 1998. ,
DOI : 10.1109/ITW.1998.706451
Joint source/channel coding for variable length codes, Proceedings DCC '98 Data Compression Conference (Cat. No.98TB100225), pp.139-148, 1998. ,
DOI : 10.1109/DCC.1998.672140
Turbo fec/vlc decoding and its application to text compression, Proc. Conf. Inform. Theory and Systems, pp.6-6, 2000. ,
Joint source-channel turbo decoding of entropy-coded sources, IEEE Journal on Selected Areas in Communications, vol.19, issue.9, pp.1680-1696, 2001. ,
DOI : 10.1109/49.947033
On the characterization of statistically synchronizable codes (Corresp.), IEEE Transactions on Information Theory, vol.26, issue.6, pp.733-735, 1980. ,
DOI : 10.1109/TIT.1980.1056266
On the characterization of statistically synchronizable variable-length codes, IEEE Transactions on Information Theory, vol.34, issue.4, pp.817-825, 1988. ,
DOI : 10.1109/18.9779
Error recovery for variable length codes, IEEE Transactions on Information Theory, vol.31, issue.6, pp.794-801, 1985. ,
DOI : 10.1109/TIT.1985.1057110
Synchronization recovery of variable-length codes, IEEE Transactions on Information Theory, vol.48, issue.1, pp.219-227, 2002. ,
DOI : 10.1109/18.971750
Self-synchronizing Huffman codes (Corresp.), IEEE Transactions on Information Theory, vol.30, issue.4, pp.687-693, 1984. ,
DOI : 10.1109/TIT.1984.1056931
On the construction of statistically synchronizable codes, IEEE Transactions on Information Theory, vol.38, issue.2, pp.407-414, 1992. ,
DOI : 10.1109/18.119696
Self-synchronizing variable-length codes for image transmission, [Proceedings] ICASSP-92: 1992 IEEE International Conference on Acoustics, Speech, and Signal Processing, pp.477-480, 1992. ,
DOI : 10.1109/ICASSP.1992.226172
Error states and synchronization recovery for variable length codes, IEEE Transactions on Communications, vol.42, issue.2/3/4, pp.783-792, 1994. ,
DOI : 10.1109/TCOMM.1994.577107
Reversible variable length codes, IEEE Transactions on Communications, vol.43, issue.2/3/4, pp.158-162, 1995. ,
DOI : 10.1109/26.380026
Reversible variable length codes for efficient and robust image and video coding, Proceedings DCC '98 Data Compression Conference (Cat. No.98TB100225), pp.471-480, 1998. ,
DOI : 10.1109/DCC.1998.672209
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.50.9139
Generalized Tunstall codes for sources with memory, IEEE Transactions on Information Theory, vol.43, issue.2, pp.658-668, 1997. ,
DOI : 10.1109/18.556121
Binary codes capable of correcting deletions, insertions and reversals, Soviet Physics Doklady, vol.10, pp.707-710, 1966. ,
Subband image coding using entropy-coded quantization over noisy channels, IEEE Journal on Selected Areas in Communications, vol.10, issue.5, pp.926-942, 1992. ,
DOI : 10.1109/49.138998
URL : http://drum.lib.umd.edu/bitstream/1903/4912/1/TR_89-73.pdf
Rate-distortion performance for joint source and channel coding of images, Proc. Intl. Conf. Image Processing, ICIP, pp.77-80, 1995. ,
Joint source-channel coding of scalable video over noisy channels, Proc. Intl. Conf. Image Processing, ICIP, pp.767-770, 1996. ,
Multiplication of multidigit numbers on automata, Soviet Physics Doklady, 1963. ,
More on squaring and multiplying large integers, IEEE Transactions on Computers, vol.43, issue.8, pp.899-908, 1994. ,
DOI : 10.1109/12.295852
URL : http://citeseerx.ist.psu.edu/viewdoc/summary?doi=10.1.1.332.9590
A study of vector quantization for noisy channels, IEEE Transactions on Information Theory, vol.36, issue.4, pp.799-809, 1990. ,
DOI : 10.1109/18.53739
A method for the construction of minimum redundancy codes, Proc. of the IRE, pp.1098-1101, 1952. ,
Constructing codes with bounded codeword lengths (Corresp.), IEEE Transactions on Information Theory, vol.20, issue.2, pp.288-290, 1974. ,
DOI : 10.1109/TIT.1974.1055176
A fast algorithm for optimal length-limited Huffman codes, Journal of the ACM, vol.37, issue.3, pp.464-473, 1990. ,
DOI : 10.1145/79147.79150
Optimal decoding of linear codes for minimizing symbol error rate (Corresp.), IEEE Transactions on Information Theory, vol.20, issue.2, pp.284-287, 1974. ,
DOI : 10.1109/TIT.1974.1055186
Reduced-complexity soft-ln-soft-out decoding of variable-length codes, IEEE International Symposium on Information Theory, 2003. Proceedings., 2003. ,
DOI : 10.1109/ISIT.2003.1228215
