Estimation problems for a class of impulsive systems, International Journal of Robust and Nonlinear Control, vol.48, issue.1 ,
DOI : 10.1002/rnc.1621
URL : https://hal.archives-ouvertes.fr/inria-00504941
Parameters estimation of systems with delayed and structured entries, Automatica, vol.45, issue.5, pp.1117-1125, 2009. ,
DOI : 10.1016/j.automatica.2008.12.026
URL : https://hal.archives-ouvertes.fr/inria-00343801
Nonlinear control of a 3-pole active magnetic bearing system, Automatica, vol.39, issue.2, pp.291-298, 2003. ,
DOI : 10.1016/S0005-1098(02)00207-8
High precision synchronous tool path tracking with an amb machine tool spindle, pp.3-6, 2004. ,
Algebraic change-point detection, Applicable Algebra in Engineering, Communication and Computing, pp.131-143, 2010. ,
DOI : 10.1007/s00200-010-0119-z
URL : https://hal.archives-ouvertes.fr/inria-00439226
An algebraic framework for linear identification, ESAIM: Control, Optimisation and Calculus of Variations, vol.9, pp.151-168, 2003. ,
DOI : 10.1051/cocv:2003008
Closed-loop Parametric Identification for Continuous-time Linear Systems via New Algebraic Techniques, Identification of Continuous-time Models from Sampled Data, Advances in Industrial Control, pp.362-391, 2008. ,
DOI : 10.1007/978-1-84800-161-9_13
URL : https://hal.archives-ouvertes.fr/inria-00114958
An algebraic parameter identification algorithm and asymptotic observers for estimation of the load of a boost converter, 2007 IEEE International Symposium on Industrial Electronics, pp.7-11, 2007. ,
DOI : 10.1109/ISIE.2007.4374563
Control of a self-bearing servomotor. Control Systems Magazine, IEEE, vol.29, issue.5, pp.74-92, 2009. ,
A nonlinear approach to the control of magnetic bearings, IEEE Transactions on Control Systems Technology, vol.4, issue.5, pp.524-544, 1996. ,
DOI : 10.1109/87.531919
Flatness-based trajectory tracking control of a rotationg shaft, Seventh International Symp. on Magnetic Bearings, pp.299-304, 2000. ,
Parameter estimation via differential algebra and operational calculus, Research Report, 2007. ,
A revised look at numerical differentiation with an application to nonlinear feedback control, 2007 Mediterranean Conference on Control & Automation, 2007. ,
DOI : 10.1109/MED.2007.4433728
URL : https://hal.archives-ouvertes.fr/inria-00142588
Numerical differentiation with annihilators in noisy environment, Numerical Algorithms, vol.14, issue.12, pp.439-467, 2009. ,
DOI : 10.1007/s11075-008-9236-1
URL : https://hal.archives-ouvertes.fr/inria-00319240
An algebraic frequency estimator for a biased and noisy sinusoidal signal, Signal Processing, vol.87, issue.6, pp.1188-1201, 2007. ,
DOI : 10.1016/j.sigpro.2006.10.006
Différenciation numérique multivariable I : estimateurs algébriques et structure, Sixième Conférence Internationale Francophone d'Automatique Nancy, 2010. ,
An Algebraic Method for Eye Blink Artifacts Detection in Single Channel EEG Recordings, 17th International Conference on Biomagnetism ? BIOMAG2010, pp.175-178, 2010. ,
DOI : 10.1007/978-3-642-12197-5_38
URL : https://hal.archives-ouvertes.fr/hal-00518627
An algebraic approach for maximum friction estimation, 8th IFAC Symposium on Nonlinear Control Systems (NOLCOS) ,
DOI : 10.3182/20100901-3-IT-2016.00212
URL : https://hal.archives-ouvertes.fr/inria-00484781
