Principe de compilation d'un langage de traitement de signal, Thèse de doctorat Laboratoire d'informatique fondamentale de Lille French), 2001. ,
Spécification multidimensionnelle pour le traitement du signal systématique, Thèse de doctorat Laboratoire d'informatique fondamentale de Lille, 2005. ,
High level loop transformations for multidimensional signal processing embedded applications, SAMOS 2008 Workshop, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00565154
Gaspard2: from MARTE to SystemC simulation, in: Modeling and Analyzis of Real-Time and Embedded Systems with the MARTE UML profile DATE'08 Workshop, 2008. ,
Array-OL with delays, a domain specific specification language for multidimensional intensive signal processing, Multidimensional Systems and Signal Processing ,
DOI : 10.1007/s11045-009-0085-4
URL : https://hal.archives-ouvertes.fr/inria-00522751
Formal semantics of Array-OL, a domain specific language for intensive multidimensional signal processing, Research Report RR, vol.6467, 2008. ,
URL : https://hal.archives-ouvertes.fr/inria-00261178
Static Scheduling of Synchronous Data Flow Programs for Digital Signal Processing, IEEE Transactions on Computers, vol.36, issue.1 ,
DOI : 10.1109/TC.1987.5009446
Multidimensional synchronous dataflow, IEEE Transactions on Signal Processing, vol.50, issue.8, pp.2064-2079, 2002. ,
DOI : 10.1109/TSP.2002.800830
Modeling and Analysis of Windowed Synchronous Algorithms, 2006 IEEE International Conference on Acoustics Speed and Signal Processing Proceedings, pp.892-895, 2006. ,
DOI : 10.1109/ICASSP.2006.1660798
The Organization of Computations for Uniform Recurrence Equations, Journal of the ACM, vol.14, issue.3, pp.563-590, 1967. ,
DOI : 10.1145/321406.321418
A formal semantics for sisal arrays, Proc. Joint Conf. Infor. Sci, 1995. ,
Single Assignment C: efficient support for high-level array operations in a functional setting, Journal of Functional Programming, vol.13, issue.6, pp.1005-1059, 2003. ,
DOI : 10.1017/S0956796802004458
UML2 Profile for Modeling Controlled Data Parallel Applications, 2006. ,
DOI : 10.1007/978-1-4020-6149-3_18
URL : https://hal.archives-ouvertes.fr/inria-00565161
Introducing control in the gaspard2 data-parallel metamodel: Synchronous approach, International Workshop MARTES: Modeling and Analysis of Real-Time and Embedded Systems, conjunction with 8th International Conference on Model Driven Engineering Languages and Systems, 2005. ,
Optimizing Compilers for Modern Architectures: A Dependence-based Approach, 2001. ,
Semi-Automatic Composition of Loop Transformations for Deep Parallelism and Memory Hierarchies, International Journal of Parallel Programming, vol.20, issue.1, pp.261-317, 2006. ,
DOI : 10.1007/s10766-006-0012-3
URL : https://hal.archives-ouvertes.fr/hal-01257288
