Pattern Recognition and Machine Learning, 2006. ,
Kendall's Advanced Theory of Statistics, 2008. ,
Globally Convergent Algorithms for Estimating Generalized Gamma Distributions in Fast Signal and Image Processing, IEEE Transactions on Image Processing, vol.17, issue.8, pp.1233-1250, 2008. ,
DOI : 10.1109/TIP.2008.926148
SAR amplitude probability density function estimation based on a generalized Gaussian model, IEEE Transactions on Image Processing, vol.15, issue.6, pp.1429-1442, 2006. ,
DOI : 10.1109/TIP.2006.871124
URL : https://hal.archives-ouvertes.fr/inria-00561372
A new statistical model for Markovian classification of urban areas in high-resolution SAR images, IEEE Transactions on Geoscience and Remote Sensing, vol.42, issue.10 ,
DOI : 10.1109/TGRS.2004.834630
URL : https://hal.archives-ouvertes.fr/hal-00556167
Reliable Methods for Estimating the <formula formulatype="inline"><tex Notation="TeX">$K$</tex></formula>-Distribution Shape Parameter, IEEE Journal of Oceanic Engineering, vol.35, issue.2, pp.288-302, 2010. ,
DOI : 10.1109/JOE.2009.2025645
Mixture Densities, Maximum Likelihood and the EM Algorithm, SIAM Review, vol.26, issue.2, pp.195-239, 1984. ,
DOI : 10.1137/1026034
Introduction aux statistiques dedeuxì eme espèce: applications des logs-moments et des logs-cumulantsàcumulantsà l'analyse des lois d'images radar, Traitement du Signal, vol.19, issue.3, pp.139-167, 2002. ,
Some Applications of the Mellin Transform in Statistics, The Annals of Mathematical Statistics, vol.19, issue.3, pp.370-379, 1948. ,
DOI : 10.1214/aoms/1177730201
Modeling SAR Images With a Generalization of the Rayleigh Distribution, IEEE Transactions on Image Processing, vol.13, issue.4, pp.527-533, 2004. ,
DOI : 10.1109/TIP.2003.818017
A Generalization of the Gamma Distribution, The Annals of Mathematical Statistics, vol.33, issue.3, pp.1187-1192, 1962. ,
DOI : 10.1214/aoms/1177704481
A model for non-Rayleigh sea echo, IEEE Transactions on Antennas and Propagation, vol.24, issue.6, pp.806-814, 1976. ,
DOI : 10.1109/TAP.1976.1141451
Understanding Synthetic Aperture Radar Images, 2004. ,
Statistical modeling of speech signals based on generalized gamma distribution, IEEE Signal Processing Letters, vol.12, issue.3, pp.258-261, 2005. ,
DOI : 10.1109/LSP.2004.840869
Image probability distribution based on generalized gamma function, IEEE Signal Processing Letters, vol.12, issue.4, pp.325-328148, 2005. ,
DOI : 10.1109/LSP.2005.843763
On the empirical-statistical modeling of SAR images with generalized gamma distribution, IEEE J. Sel. Top. Signal Process, vol.5, issue.3, pp.386-397, 2011. ,
Unsupervised Synthetic Aperture Radar Image Segmentation Using Fisher Distributions, IEEE Transactions on Geoscience and Remote Sensing, vol.47, issue.8, pp.472966-2972, 2009. ,
DOI : 10.1109/TGRS.2009.2014364
URL : https://hal.archives-ouvertes.fr/hal-00437471
Application of the Matrix-Variate Mellin Transform to Analysis of Polarimetric Radar Images, IEEE Transactions on Geoscience and Remote Sensing, vol.49, issue.6 ,
DOI : 10.1109/TGRS.2010.2103945
Modeling the amplitude statistics of ultrasonic images, IEEE Transactions on Medical Imaging, vol.25, issue.2, pp.229-240, 2006. ,
DOI : 10.1109/TMI.2005.862664
Supervised High-Resolution Dual-Polarization SAR Image Classification by Finite Mixtures and Copulas, IEEE Journal of Selected Topics in Signal Processing, vol.5, issue.3, pp.554-566, 2011. ,
DOI : 10.1109/JSTSP.2010.2103925
URL : https://hal.archives-ouvertes.fr/inria-00562326
Inference in the Generalized Gamma and Log Gamma Distributions, Technometrics, vol.11, issue.3, pp.409-419, 1980. ,
DOI : 10.1080/00401706.1980.10486173
Computing Maximum-Likelihood Parameter Estimates of the Generalized Gamma Distribution by Numerical Root Isolation, IEEE Transactions on Reliability, vol.36, issue.5, pp.586-590, 1987. ,
DOI : 10.1109/TR.1987.5222478
Inferential Procedures for the Generalized Gamma Distribution, Journal of the American Statistical Association, vol.11, issue.332, pp.1601-1609, 1970. ,
Parameter Estimation in Reliability and Life Span Models, 1988. ,
Maximum likelihood parameter estimation by model augmentation with applications to the extended four-parameter generalized gamma distribution, Mathematics and Computers in Simulation, vol.54, issue.1-3, pp.81-97, 2000. ,
DOI : 10.1016/S0378-4754(00)00201-9
The generalized method of moments as applied to the generalized gamma distribution, Stochastic Hydrology and Hydraulics, vol.7, issue.3, pp.161-174, 1988. ,
DOI : 10.1007/BF01550839
Mathematical Methods of Statistics, 1946. ,
Maximum likelihood estimation of Kdistribution parameters via the expectation-maximization algorithm, IEEE Trans. Signal Process, vol.48, issue.12, pp.3303-3306, 2000. ,
A method for estimating the parameters of the K distribution, IEEE Transactions on Signal Processing, vol.47, issue.4, pp.1147-1151, 1999. ,
DOI : 10.1109/78.752614
Efficient approximate energy minimization via graph cuts, IEEE Trans. Patt. Anal. Mach. Intell, vol.20, issue.12, pp.1222-1239, 2001. ,
What energy functions can be minimized via graph cuts?, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.26, issue.2, pp.147-159, 2004. ,
DOI : 10.1109/TPAMI.2004.1262177
An experimental comparison of min-cut/max- flow algorithms for energy minimization in vision, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.26, issue.9, pp.1124-1137, 2004. ,
DOI : 10.1109/TPAMI.2004.60
Analysis on Manifolds, 1991. ,
On some properties of digamma and polygamma functions, Journal of Mathematical Analysis and Applications, vol.328, issue.1, pp.452-465, 2007. ,
DOI : 10.1016/j.jmaa.2006.05.065
