The dimension of ergodic random sequences - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2011
Let \mu be a computable ergodic shift-invariant measure over the Cantor space. Providing a constructive proof of Shannon-McMillan-Breiman theorem, V'yugin proved that if a sequence x is Martin-Löf random w.r.t. \mu then the strong effective dimension Dim(x) of x equals the entropy of \mu. Whether its effective dimension dim(x) also equals the entropy was left as an problem question. In this paper we settle this problem, providing a positive answer. A key step in the proof consists in extending recent results on Birkhoff's ergodic theorem for Martin-Löf random sequences.
paperbiblio.pdf (115.19 Ko) Télécharger le fichier
inria-00606457 , version 1 (06-07-2011)
inria-00606457 , version 2 (06-07-2011)
inria-00606457 , version 3 (11-07-2011)
inria-00606457 , version 4 (21-07-2011)
  • HAL Id : inria-00606457 , version 2
  • ARXIV : 1107.1149
Mathieu Hoyrup. The dimension of ergodic random sequences. [Research Report] 2011. ⟨inria-00606457v2⟩
182 Consultations
209 Téléchargements
