Rendering Techniques (Proceeding Eurographics Workshop on Rendering) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ouvrage (Y Compris Édition Critique Et Traduction) Année : 1998
Some of the best current research on realistic rendering is included in this volume. It emphasizes the current "hot topics" in this field: image based rendering, and efficient local and global-illumination calculations. In the first of these areas, there are several contributions on real-world model acquisition and display, on using image-based techniques for illumination and on efficient ways to parameterize and compress images or light fields, as well as on clever uses of texture and compositing hardware to achieve image warping and 3D surface textures. In global and local illumination, there are contributions on extending the techniques beyond diffuse reflections, to include specular and more general angle dependent reflection functions, on efficiently representing and approximating these reflection functions, on representing light sources and on approximating visibility and shadows. Finally, there are two contributions on how to use knowledge about human perception to concentrate the work of accurate rendering only where it will be noticed, and a survey of computer graphics techniques used in the production of a feature length computer-animated film with full 3D characters.
Fichier non déposé
inria-00606703 , version 1 (07-07-2011)
  • HAL Id : inria-00606703 , version 1
George Drettakis, Nelson Max. Rendering Techniques (Proceeding Eurographics Workshop on Rendering). Springer Verlag, Wien, 1998, 978-3-211-83213-4. ⟨inria-00606703⟩
87 Consultations
0 Téléchargements
