Flexible Point-Based Rendering on Mobile Devices - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Computer Graphics and Applications Année : 2004
Point-based rendering is a compact and efficient means of displaying complex geometry. Our goal is to enable flexible point-based rendering, permitting local image refinement, required for example when zooming into very complex scenes, and efficient shadow computations. We use hierarchical packed point representations, based on recursive grid data structures. Such compact structures are particularly well adapted to devices with limited memory and display resolution, such as PDA's. To achieve flexible rendering we store intermediate attributes such as normals and colors at internal nodes of the hierarchy. We examine the memory and computation tradeoffs involved in the type of structure used, and find that tri-grids (3x3x3 hierarchical grids) are a suitable compromise for many cases. We show implementations of our method on PC and on a PDA, for octrees and tri-grids. The PDA version can render objects sampled by 1.3 million points at 2.1 frames per second.
tgpbr-cga.pdf (1.74 Mo) Télécharger le fichier
DD04.avi (27.16 Mo) Télécharger le fichier
Format : Figure, Image
Format : Autre
inria-00606748 , version 1 (22-07-2011)
Florent Duguet, George Drettakis. Flexible Point-Based Rendering on Mobile Devices. IEEE Computer Graphics and Applications, 2004, 24 (4), pp.57-63. ⟨10.1109/MCG.2004.5⟩. ⟨inria-00606748⟩
212 Consultations
189 Téléchargements
