Image-based Techniques for the Creation and Display of Photorealistic Interactive Virtual Environments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2004
In this paper we introduce an image-based 3D capture process for the creation and display of photorealistic virtual environments (VEs). The resulting VEs aim to realistically recreate existing real-world scenes that can be displayed in a range of immersive VR systems using a high-quality, view-dependent algorithm and further enhanced using advanced vegetation, shadow display algorithms and 3D sound. The scenes, an archaeological site and an urban environment, were chosen according to real-world applications in the areas of urban planning/architecture and cultural heritage education. The users in each case are able to reconstruct or manipulate elements of the VEs according to their needs, as these have been specified through a detailed user requirements survey. Furthermore, a user task analysis and scenario-based approach has been adopted for the design of the virtual prototypes and the evaluation, which is currently underway. This work is being developed in the context of the EU-funded research project CREATE and the first examples of the prototype system in use are described and demonstrated in this paper.
DrettakisFinalElec.pdf (2.68 Mo) Télécharger le fichier
DrettakisFinalPress.pdf (2.65 Mo) Télécharger le fichier
Format : Figure, Image
Format : Autre
inria-00606753 , version 1 (21-07-2011)
  • HAL Id : inria-00606753 , version 1
George Drettakis, Maria Roussou, Nicolas Tsingos, Alex Reche, Emmanuel Gallo. Image-based Techniques for the Creation and Display of Photorealistic Interactive Virtual Environments. Proceedings of the Eurographics Symposium on Virtual Environments, Jun 2004, Grenoble, France. pp.9. ⟨inria-00606753⟩
Collections
CSTB INRIA INRIA2
200 Consultations
144 Téléchargements
