Accurate Interactive Specular Reflections on Curved Objects - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2005
We present a new method to compute interactive reflections on curved objects. The approach creates virtual reflected objects which are blended into the scene. We use a property of the reflection geometry which allows us to efficiently and accurately find the point of reflection for every reflected vertex, using only reflector geometry and normal information. This reflector information is stored in a pair of appropriate cubemaps, thus making it available during rendering. The implementation presented achieves interactive rates on reasonablysized scenes. In addition,we introduce an interpolation method to control the accuracy of our solution depending on the required frame rate.
pau_estalella.pdf (1.35 Mo) Télécharger le fichier
EMDTDC05.avi (22.44 Mo) Télécharger le fichier
annex.pdf (74.41 Ko) Télécharger le fichier
color_page.pdf (2.12 Mo) Télécharger le fichier
Format : Figure, Image
Format : Autre
Format : Autre
Format : Autre
inria-00606757 , version 1 (20-07-2011)
  • HAL Id : inria-00606757 , version 1
Pau Estalella, Ignacio Martin, George Drettakis, Dani Tost, Olivier Devillers, et al.. Accurate Interactive Specular Reflections on Curved Objects. Vision Modeling and Visualization (VMV 2005), Nov 2005, Erlangen, Germany. pp.8. ⟨inria-00606757⟩
188 Consultations
219 Téléchargements
