Effective Multi-resolution Rendering and Texture Compression for Captured Volumetric Trees - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Trees can be realistically rendered in synthetic environments by creating volumetric representations from photographs. However, volumetric tree representations created with previous methods are expensive to render due to the high number of primitives, and have very high texture memory requirements. We address both shortcomings by presenting an efficient multi-resolution rendering method and an effective texture compression solution. Our method uses an octree with appropriate textures at intermediate hierarchy levels and applies an effective pruning strategy. For texture compression, we adapt a vector quantization approach in a perceptually accurate color space, and modify the codebook generation of the Generalized Lloyd Algorithm to further improve texture quality. In combination with several hardware acceleration techniques, our approach achieves a reduction in texture memory requirements by one order of magnitude; in addition, it is now possible to render tens or even hundreds of captured trees at interactive rates.
LRDM06.pdf (4.55 Mo) Télécharger le fichier
LRDM06.avi (18.04 Mo) Télécharger le fichier
Format : Figure, Image
Format : Autre
inria-00606776 , version 1 (19-07-2011)
Christian Linz, Alex Reche, George Drettakis, Marcus Magnor. Effective Multi-resolution Rendering and Texture Compression for Captured Volumetric Trees. Eurographics Workshop on Natural Phenomena, Sep 2006, Vienne, Austria. pp.83-90, ⟨10.2312/NPH/NPH06/083-090⟩. ⟨inria-00606776⟩
Collections
CSTB INRIA INRIA2
554 Consultations
417 Téléchargements
