Image-Guided Weathering: A New Approach Applied to Flow Phenomena
Abstract : The simulation of weathered appearance is essential in the realistic modeling of urban environments. A representative and particularly difficult effect to produce on a large scale is the effect of fluid flow. Changes in appearance due to flow are the result of both the global effect of large-scale shape, and local effects, such as the detailed roughness of a surface. With digital photography and Internet image collections, visual examples of flow effects are readily available. These images, however, mix the appearance of flows with the specific local context. We present a methodology to extract parameters and detail maps from existing imagery in a form that allows new target-specific flow effects to be produced, with natural variations in the effects as they are applied in different locations in a new scene. In this paper, we focus on producing a library of parameters and detail maps for generating flow patterns – and this methodology can be used to extend the library with additional image exemplars. To illustrate our methodology, we show a rich collection of patterns applied to urban models.
Type de document :
Article dans une revue
ACM Transactions on Graphics, Association for Computing Machinery, 2011, 30 (3), 〈10.1145/1966394.1966399〉
Liste complète des métadonnées
https://hal.inria.fr/inria-00606830
Contributeur : Team Reves <>
Soumis le : jeudi 7 juillet 2011 - 11:18:42
Dernière modification le : samedi 27 janvier 2018 - 01:30:40
Document(s) archivé(s) le : dimanche 4 décembre 2016 - 20:23:40
Collections
Citation
Carles Bosch, Pierre-Yves Laffont, Holly Rushmeier, Julie Dorsey, George Drettakis. Image-Guided Weathering: A New Approach Applied to Flow Phenomena. ACM Transactions on Graphics, Association for Computing Machinery, 2011, 30 (3), 〈10.1145/1966394.1966399〉. 〈inria-00606830〉
Métriques
Consultations de la notice
357
Téléchargements de fichiers
476
