On the Number of Distinct Legendre, Jacobi,Hessian and Edwards Curves (Extended Abstract) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Reza Rezaeian Farashahi
  • Fonction : Auteur
  • PersonId : 905231
We give explicit formulas for the number of distinct elliptic curves over a nite eld, up to isomorphism, in the families of Legendre, Jacobi, Hessian and Edwards curves.
76.pdf (134.06 Ko) Télécharger le fichier
inria-00607279 , version 1 (08-07-2011)
  • HAL Id : inria-00607279 , version 1
Reza Rezaeian Farashahi. On the Number of Distinct Legendre, Jacobi,Hessian and Edwards Curves (Extended Abstract). WCC 2011 - Workshop on coding and cryptography, Apr 2011, Paris, France. pp.37-46. ⟨inria-00607279⟩
Collections
WCC2011 TDS-MACS
103 Consultations
562 Téléchargements
