Exact Minimum Density of Codes Identifying Vertices in the Square Grid, SIAM Journal on Discrete Mathematics, vol.19, issue.1, pp.69-82, 2005. ,
DOI : 10.1137/S0895480104444089
General bounds for identifying codes in some infinite regular graphs, Electron. J. Combin, vol.8, issue.1, 2001. ,
The minimum density of an identifying code in the king lattice, Discrete Mathematics, vol.276, issue.1-3, pp.95-109, 2004. ,
DOI : 10.1016/S0012-365X(03)00306-6
Identifying codes with small radius in some infinite regular graphs, Electron. J. Combin, vol.9, issue.1, 2002. ,
Bounds for Codes Identifying Vertices in the Hexagonal Grid, SIAM Journal on Discrete Mathematics, vol.13, issue.4, pp.492-504, 2000. ,
DOI : 10.1137/S0895480199360990
A new lower bound on the density of vertex identifying codes for the infinite hexagonal grid, Electron. J. Combin, vol.16, issue.16, 2009. ,
On Identifying Codes in the Triangular and Square Grids, SIAM Journal on Computing, vol.33, issue.2, pp.304-312, 2004. ,
DOI : 10.1137/S0097539703433110
Optimal lower bound for 2-identifying code in the hexagonal grid, 2010. ,
On a new class of codes for identifying vertices in graphs, IEEE Transactions on Information Theory, vol.44, issue.2, pp.599-611, 1998. ,
DOI : 10.1109/18.661507
Lower bounds for identifying codes in some infinite grids, Electron. J. Combin, vol.17, issue.122, 2010. ,
Fault-tolerant locating-dominating sets, Discrete Mathematics, vol.249, issue.1-3, pp.179-189, 2002. ,
DOI : 10.1016/S0012-365X(01)00244-8
URL : http://doi.org/10.1016/s0012-365x(01)00244-8
