Minimum Weight and Dimension Formulas for Some Geometric Codes, Designs, Codes and Cryptography, vol.17, issue.1/3, pp.105-120, 1999. ,
DOI : 10.1023/A:1008362706649
Dual codes of projective planes of order 25, Advances in Geometry, vol.3, issue.s1, pp.140-152, 2003. ,
DOI : 10.1515/advg.2003.2003.s1.140
Small weight codewords in the dual code of points and hyperplanes in PG(n, q), q even, Designs, Codes and Cryptography, vol.95, issue.1 ,
DOI : 10.1007/s10623-011-9543-8
On (q + t)-arcs of type, Des. Codes Cryptogr, vol.2, issue.29, pp.131-139, 2003. ,
On a class of majority-logic decodable cyclic codes, IEEE Transactions on Information Theory, vol.14, issue.2, pp.182-188, 1968. ,
DOI : 10.1109/TIT.1968.1054126
The rank of the incidence matrix of points and d-flats in finite geometries, J. Sci. Hiroshima Univ, vol.32, pp.381-396, 1969. ,
Ternary dual codes of the planes of order nine, Journal of Statistical Planning and Inference, vol.95, issue.1-2, pp.229-236, 2001. ,
DOI : 10.1016/S0378-3758(00)00290-1
A lower bound for the minimum weight of the dual 7-ary code of a projective plane of order 49, Designs, Codes and Cryptography, vol.8, issue.1-3, pp.133-142, 2007. ,
DOI : 10.1007/s10623-007-9072-7
On ( q + t)-arcs of type (0, 2, t) in a desarguesian plane of order q, Math. Proc. Camb, pp.445-459, 1990. ,
DOI : 10.1007/BF01225209
Linear codes from projective spaces, Error-Correcting Codes, Finite Geometries, and Cryptography. AMS Contemporary Mathematics (CONM) book series, pp.185-202, 2010. ,
DOI : 10.1090/conm/523/10326
On the code generated by the incidence matrix of points and k-spaces in PG (n, q) and its dual. Finite Fields Appl, pp.1020-1038, 2008. ,
Codes of Desarguesian projective planes of even order, projective triads and (q + t, t)-arcs of type ,
