Optimal Arcs in Hjelmslev Spaces of Large Dimension
In this paper, we present various results on arcs in projective threedimensional Hjelmslev spaces over finite chain rings of nilpotency index 2. A table is given containing exact values and bounds for projective arcs in the geometries over the two chain rings with four elements.
