Computing the Distance between Piecewise-Linear Bivariate Functions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We consider the problem of computing the distance between two piecewise-linear bivariate functions $f$ and $g$ defined over a common domain $M$. We focus on the distance induced by the $L_2$-norm, that is $\|f-g\|_2=\sqrt{\iint_M (f-g)^2}$. If $f$ is defined by linear interpolation over a triangulation of $M$ with $n$ triangles, while $g$ is defined over another such triangulation, the obvious naïve algorithm requires $\Theta(n^2)$ arithmetic operations to compute this distance. We show that it is possible to compute it in $\O(n\log^4 n)$ arithmetic operations, by reducing the problem to multi-point evaluation of a certain type of polynomials. We also present an application to terrain matching.
integral.pdf (145.81 Ko) Télécharger le fichier
inria-00608255 , version 1 (12-07-2011)
inria-00608255 , version 2 (12-07-2011)
  • HAL Id : inria-00608255 , version 2
  • ARXIV : 1107.2312
Guillaume Moroz, Boris Aronov. Computing the Distance between Piecewise-Linear Bivariate Functions. SODA - Proceedings of the Twenty-Third Annual ACM-SIAM Symposium on Discrete Algorithms - 2012, Jan 2012, Kyoto, Japan. ⟨inria-00608255v2⟩
248 Consultations
375 Téléchargements
