On-line parameter estimation of a magnetic bearing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This article presents a parameter estimation algorithm for a magnetic bearing. Such process have strongly nonlinear dynamics andare inherently unstable systems. A simplified model of the magnetic bearing is developed in order to be able to estimate certain parameters. These parameters are difficult to measure, and may slightly vary over time. The expression of the estimates is written as a function of integrals of the inputs and outputs of the system. The experiments show a fast and robust on-line identification.
article_Final.pdf (756.06 Ko) Télécharger le fichier
inria-00608380 , version 1 (13-07-2011)
inria-00608380 , version 2 (13-07-2011)
  • HAL Id : inria-00608380 , version 2
Romain Delpoux, Thierry Floquet. On-line parameter estimation of a magnetic bearing. Med11, Jun 2011, Corfu, Greece. ⟨inria-00608380v2⟩
195 Consultations
232 Téléchargements
