Real-time visuomotor update of an active binocular head
Abstract : In order for a binocular head to perform optimal 3D tracking, it should be able to verge its cameras actively, while maintaining geometric calibration. In this work we introduce a calibration update procedure, which allows a robotic head to simultaneously fixate, track, and reconstruct a moving object in real-time. The update method is based on a mapping from motor-based to image-based estimates of the camera orientations, estimated in an offline stage. Following this, a fast online procedure is presented to update the calibration of an active binocular camera pair. The proposed approach is ideal for active vision applications because no image-processing is needed at runtime for the scope of calibrating the system or for maintaining the calibration parameters during camera vergence. We show that this homography-based technique allows an active binocular robot to fixate and track an object, whilst performing 3D reconstruction concurrently in real-time.
Complete list of metadatas
https://hal.inria.fr/inria-00608769
Contributor : Team Perception <>
Submitted on : Monday, August 27, 2012 - 2:03:50 PM
Last modification on : Monday, June 17, 2019 - 5:10:07 PM
Long-term archiving on: Wednesday, November 28, 2012 - 3:31:50 AM
Sapienza-RR.pdf
Identifiers
  • HAL Id : inria-00608769, version 2
Collections
Citation
Michael Sapienza, Miles Hansard, Radu Horaud. Real-time visuomotor update of an active binocular head. [Research Report] RR-7682, 2012. ⟨inria-00608769v2⟩
Share
Metrics
Record views
27
Files downloads
71
