Coupling Local and Global Shape Optimization in Aerodynamic Design - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2011
Wing design in aerodynamics requires the definition of global geometrical characteristics, such as span, root/tip length ratio, angle of attack, twist angle, sweep angle, etc, as well as local geometrical features that determine the wing section. The objective of this study is to propose an efficient algorithm to achieve the optimization of both global and local shape parameters. We consider as testcase the drag minimization, under lift constraint, of the wing shape of a business aircraft in transonic regime, the flow being modeled by the compressible Euler equations. We show that a straightforward optimization of all parameters fails, due to multimodality of the optimization problem. Then, some alternative strategies are proposed. Among them, the use of virtual Nash games yields the best results, in terms of cost function value obtained as well as computational efficiency.
RR-7684.pdf (1.15 Mo) Télécharger le fichier
inria-00608846 , version 1 (15-07-2011)
  • HAL Id : inria-00608846 , version 1
Régis Duvigneau. Coupling Local and Global Shape Optimization in Aerodynamic Design. [Research Report] RR-7684, INRIA. 2011. ⟨inria-00608846⟩
183 Consultations
127 Téléchargements
