Numerical differentiation on irregular grids - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this article, we propose a multidimensional numerical differentiation method from irregularly sampled data, in a noisy environment. The method extends to irregular grids our previous work and it relies on the same spirit as the algebraic numerical differentiators due to M. Mboup et al. ("Numerical differentiation with annihilators in noisy environment," Numerical Algorithm, 50, pp. 439-457, 2009). We provide a least squares interpretation of the developed estimators as well as a discrete implementation scheme. Several numerical simulations are presented to asses the performance of the proposed differentiators.
Automatique
Irregular-Grid.pdf (298.46 Ko) Télécharger le fichier
inria-00609028 , version 1 (04-04-2012)
  • HAL Id : inria-00609028 , version 1
Samer Riachy, Mamadou Mboup, Jean-Pierre Richard. Numerical differentiation on irregular grids. WIFAC, Aug 2011, Milan, Italy. ⟨inria-00609028⟩
357 Consultations
2085 Téléchargements
