Preprints, Working Papers, ...
Certified metamodels for sensitivity indices estimation
Alexandre Janon 1, 2 Maëlle Nodet 1 Clémentine Prieur 1
1 MOISE - Modelling, Observations, Identification for Environmental Sciences
Inria Grenoble - Rhône-Alpes, LJK - Laboratoire Jean Kuntzmann, Grenoble INP [2007-2019] - Institut polytechnique de Grenoble - Grenoble Institute of Technology [2007-2019]
Abstract : Global sensitivity analysis of a numerical code, more specifically estimation of Sobol indices associated with input variables, generally requires a large number of model runs. When those demand too much computation time, it is necessary to use a reduced model (metamodel) to perform sensitivity analysis, whose outputs are numerically close to the ones of the original model, while being much faster to run. In this case, estimated indices are subject to two kind of errors: sampling error, caused by the computation of the integrals appearing in the definition of the Sobol indices by a Monte-Carlo method, and metamodel error, caused by the replacement of the original model by the metamodel. In cases where we have certified bounds for the metamodel error, we propose a method to quantify both types of error, and we compute confidence intervals for first-order Sobol indices.
Complete list of metadatas
https://hal.inria.fr/inria-00609059
Contributor : Alexandre Janon <>
Submitted on : Monday, July 18, 2011 - 7:46:37 AM
Last modification on : Thursday, July 9, 2020 - 9:44:32 AM
Document(s) archivé(s) le : Monday, November 12, 2012 - 11:11:08 AM
Identifiers
  • HAL Id : inria-00609059, version 1
  • ARXIV : 1107.3542
Citation
Alexandre Janon, Maëlle Nodet, Clémentine Prieur. Certified metamodels for sensitivity indices estimation. 2011. ⟨inria-00609059v1⟩
Share
Metrics
Record views
79
Files downloads
65
