Optimal distributed algorithms for minimum weight spanning tree, counting, leader election, and related problems, Proceedings of the nineteenth annual ACM conference on Theory of computing , STOC '87, 1987. ,
DOI : 10.1145/28395.28421
A particle filtering method for wireless sensor network localization with an aerial robot beacon, 2008 IEEE International Conference on Robotics and Automation, pp.596-601, 2008. ,
DOI : 10.1109/ROBOT.2008.4543271
A Distributed Algorithm for Minimum-Weight Spanning Trees, ACM Transactions on Programming Languages and Systems, vol.5, issue.1, pp.66-77, 1983. ,
DOI : 10.1145/357195.357200
Introduction to Algorithms, 2002. ,
http://defense-update.com/products/g/gps-aj ,
Monte Carlo localization of wireless sensor networks with a single mobile beacon, Wireless Networks, pp.978-990, 2009. ,
DOI : 10.1007/s11276-008-0096-3
Robot assisted localization of sensor networks guided by rigidity, Proceedings of the 4th International ICST Conference on Wireless Internet, 2008. ,
DOI : 10.4108/ICST.WICON2008.4817
MBAL: A Mobile Beacon-Assisted Localization Scheme for Wireless Sensor Networks, 2007 16th International Conference on Computer Communications and Networks, pp.57-62, 2007. ,
DOI : 10.1109/ICCCN.2007.4317797
Sensor node localization using mobile acoustic beacons, IEEE International Conference on Mobile Adhoc and Sensor Systems Conference, 2005., 2005. ,
DOI : 10.1109/MAHSS.2005.1542835
URL : http://etd.library.vanderbilt.edu/available/etd-07292005-140032/unrestricted/ms-thesis-manish-kushwaha.pdf
Design and analysis of an MST-based topology control algorithm, IEEE INFOCOM 2003. Twenty-second Annual Joint Conference of the IEEE Computer and Communications Societies (IEEE Cat. No.03CH37428), pp.1195-1206, 2005. ,
DOI : 10.1109/INFCOM.2003.1209193
Node localization using mobile robots in delay-tolerant sensor networks, IEEE Transactions on Mobile Computing, vol.4, issue.3, pp.285-295, 2005. ,
DOI : 10.1109/TMC.2005.43
Mobile-assisted localization in wireless sensor networks, Proceedings IEEE 24th Annual Joint Conference of the IEEE Computer and Communications Societies., 2005. ,
DOI : 10.1109/INFCOM.2005.1497889
Localization of wireless sensor networks with a mobile beacon, 2004 IEEE International Conference on Mobile Ad-hoc and Sensor Systems (IEEE Cat. No.04EX975), 2004. ,
DOI : 10.1109/MAHSS.2004.1392104
Adapting Mobile Beacon-Assisted Localization in Wireless Sensor Networks, Sensors, vol.9, issue.4, pp.2760-2779, 2009. ,
DOI : 10.3390/s90402760
A survey on sensor localization, Journal of Control Theory and Applications, vol.1, issue.1, pp.2-11, 2010. ,
DOI : 10.1007/s11768-010-9187-7
A simplified analytical model for predicting path loss in urban and suburban environments, IEEE Transactions on Vehicular Technology, vol.46, issue.4, pp.1040-1046, 1997. ,
DOI : 10.1109/25.653077
A Walking Beacon-Assisted Localization in Wireless Sensor Networks, 2007 IEEE International Conference on Communications, 2007. ,
DOI : 10.1109/ICC.2007.510
A Novel Distributed Sensor Positioning System Using the Dual of Target Tracking, IEEE Transactions on Computers, vol.57, issue.2, pp.246-260, 2008. ,
DOI : 10.1109/TC.2007.70792
Static Path Planning for Mobile Beacons to Localize Sensor Networks, Fifth Annual IEEE International Conference on Pervasive Computing and Communications Workshops (PerComW'07), pp.323-330, 2007. ,
DOI : 10.1109/PERCOMW.2007.109
Path planning of mobile landmarks for localization in wireless sensor networks, Computer Communications, vol.30, issue.13, pp.2577-2592, 2007. ,
DOI : 10.1016/j.comcom.2007.05.048
