Timestepping Schemes Based On Time Discontinuous Galerkin Methods - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The contribution deals with timestepping schemes for nonsmooth dynamical systems. So far, these schemes are locally of order one, both in smooth and nonsmooth segments. This is inefficient for applications with few events like circuit breakers. To consistently improve the behavior during smooth episodes, the traditional schemes are being embedded in time discontinuous Galerkin methods. After establishing the correct mathematical setting, a Petrov-Galerkin distributional differential inclusion is outlined. The bouncing ball example illustrates the capabilities.
Fichier non déposé
inria-00609888 , version 1 (20-07-2011)
  • HAL Id : inria-00609888 , version 1
Thorsten Schindler, Vincent Acary. Timestepping Schemes Based On Time Discontinuous Galerkin Methods. ICIAM 2011 - 7th International Congress on Industrial and Applied Mathematics, SIAM, Jul 2011, Vancouver, Canada. ⟨inria-00609888⟩
187 Consultations
0 Téléchargements
