Impact of Storage Technology on Cluster-Based High-Dimensional Indexing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2011
The scale of multimedia data collections is expanding at a very fast rate. In order to cope with this growth, the high-dimensional indexing methods used for content-based multimedia retrieval must adapt gracefully to secondary storage. Recent progress in storage technology, however, means that algorithm designers must now cope with a spectrum of secondary storage solutions, ranging from traditional magnetic hard drives to state-of-the-art solid state disks. This paper studies the impact of storage technology on a simple, prototypical high-dimensional indexing method for large scale query processing. We show that while the algorithm implementation deeply impacts the performance of the indexing method, the setup of the underlying storage technology is equally important.
disk.pdf (259.34 Ko) Télécharger le fichier
inria-00610446 , version 1 (22-07-2011)
  • HAL Id : inria-00610446 , version 1
Gylfi Þór Guðmundsson, Laurent Amsaleg, Björn Þór Jónsson. Impact of Storage Technology on Cluster-Based High-Dimensional Indexing. [Research Report] RR-7681, INRIA. 2011. ⟨inria-00610446⟩
256 Consultations
111 Téléchargements
