E. Vincent, M. Jafari, S. A. Abdallah, M. D. Plumbley, and M. E. Davies, Probabilistic Modeling Paradigms for Audio Source Separation, Machine Audition: Principles, Algorithms and Systems. IGI Global, pp.162-185, 2010.
DOI : 10.4018/978-1-61520-919-4.ch007
URL : https://hal.archives-ouvertes.fr/inria-00544016
A. Ozerov, E. Vincent, and F. Bimbot, A General Flexible Framework for the Handling of Prior Information in Audio Source Separation, IEEE Transactions on Audio, Speech, and Language Processing, vol.20, issue.4
DOI : 10.1109/TASL.2011.2172425
URL : https://hal.archives-ouvertes.fr/inria-00536917
M. Parvaix, L. Girin, and J. Brossier, A Watermarking-Based Method for Informed Source Separation of Audio Signals With a Single Sensor, IEEE Transactions on Audio, Speech, and Language Processing, vol.18, issue.6, pp.1464-1475, 2010.
DOI : 10.1109/TASL.2009.2035216
URL : https://hal.archives-ouvertes.fr/hal-00486809
M. Parvaix and L. Girin, Informed Source Separation of Linear Instantaneous Under-Determined Audio Mixtures by Source Index Embedding, IEEE Transactions on Audio, Speech, and Language Processing, vol.19, issue.6, pp.1721-1733, 2011.
DOI : 10.1109/TASL.2010.2097250
URL : https://hal.archives-ouvertes.fr/hal-00695763
A. Liutkus, J. Pinel, R. Badeau, L. Girin, and G. Richard, Informed source separation through spectrogram coding and data embedding, Signal Processing, vol.92, issue.8
DOI : 10.1016/j.sigpro.2011.09.016
URL : https://hal.archives-ouvertes.fr/hal-00643957
M. Parvaix, L. Girin, L. Daudet, J. Pinel, and C. Baras, Hybrid coding/indexing strategy for informed source separation of linear instantaneous under-determined audio mixtures, Proceedings of 20th International Congress on Acoustics, 2010.
URL : https://hal.archives-ouvertes.fr/hal-00535684
R. M. Gray, Source coding theory, 1990.
DOI : 10.1007/978-1-4613-1643-5
W. B. Kleijn and A. Ozerov, Rate Distribution Between Model and Signal, 2007 IEEE Workshop on Applications of Signal Processing to Audio and Acoustics, pp.243-246, 2007.
DOI : 10.1109/ASPAA.2007.4393033
D. Zhao, J. Samuelsson, and M. Nilsson, On entropy-constrained vector quantization using gaussian mixture models, IEEE Transactions on Communications, vol.56, issue.12, pp.2094-2104, 2008.
DOI : 10.1109/TCOMM.2008.070357
E. Vincent, R. Gribonval, and M. Pumbley, Oracle estimators for the benchmarking of source separation algorithms, Signal Processing, vol.87, issue.8, pp.1933-1950, 2007.
DOI : 10.1016/j.sigpro.2007.01.016
URL : https://hal.archives-ouvertes.fr/inria-00545156
J. Engdegård, B. Resch, C. Falch, O. Hellmuth, J. Hilpert et al., Spatial audio object coding (SAOC) The upcoming MPEG standard on parametric object based audio coding, 124th AES Convention, 2008.
